Background:
New to me 17' Checkmate Sportfire with a Merc 150 that has been worked over: 1:1 gears, tuner, nosecone, powerlift, punched out .30, lightweight rods and pistons.
(I just confirmed the background info on the motor last week after talking to the guy who built it up. I think the key piece of info here is the gears.)
After struggling getting the boat out of the hole, I realized that I was missing some spark on some cylinders. Cleaned all the connections, and installed new switch boxes, and had good healthy spark on all 6. Compression is 115-125 on all 6, fuel supply is good.
Today took the boat out again after doing the work. Originally had the Trophy (4-blade) 26p on there. It still bogs out of the hole. Changed to the aluminum (backup prop) 3-blade 21p and it's better but not good at all. Seeing that I just learned that this motor has 1:1 gears, I am starting to question the prop pitch and thing things may be way off here. I want to ski, and be able to move across the lake at more than 40mph. I found with the 21 on there I could slow down to almost a crawl and get on it and it would take right off, but if I stopped, it can't even get going without really playing with tilt and lift in a way that I shouldn't have to. Once on plane and accelerating, the thing really goes great. However, I am not even close to the right (from what I am told) RPMs.
Met a guy with another checkmate who had the same version motor as me except it was a mariner. He stated that his prop was either a 19 or a 17 (he wasnt' sure) but after hearing that I am thinking that he probably doesn't have 1:1 gears either.
Here are my stats for WOT:
50 mph @ 5400 RPM with the 21p
When I try to take off, it just bogs horribly. This is without a skier. I am thinking that I am going to need a MUCH lower pitch prop, but wanted to check with everyone else to see if it seems like I am on the right track. I have been over the motor a LOT and everything seems like it is running just fine and the only problem I have is holeshot.
Does this seem right? Am I on the right track? How low do I go (pitch)? I know I want to go with a 4-blade so I can yank a skier.
Thanks in advance for your expert advice!!
