wheel bearrings-how to replace?
wajajaja
I'm a newbe, whats involved mechanicaly with changeing the wheel bearings. looking at several internet sources suggest that i might wanna buy preassembled hubs/ and spindles. <br /> what does it take to change a spindle on a trailer. <br /><br />thanks walter.
lilthundr
Re: wheel bearrings-how to replace?
If you have not done that sort of thing before,it may be best to buy the whole assembly. Easier to install and since all the parts are now new, you will not have to worry about it for some time.<br />This would also be the best time to add a pair of bearing buddies to make sure the bearings never get dried out. Check the buddies once in a while and refill them with grease if needed<br />Good Luck
djvan
Spindles aren't something you want to tackle, unless you can weld as most are welded on. I don't know if hub kits come ready to install or not. By this I mean I don't know if the bearings are packed with grease. It wouldn't hurt to check. Bearing buddys for sure on a boat trailer.<br /><br />DougV>
Seaboo2
Changing bearings is an easy task (I think, but I am a professional mechanic, so my view may be tainted). If you havent froze a bearing (had it lock up) I see NO reason to replace the spindle. It may be a good idea to have one in the tool box for long road trips (they are impossiable to find at 3 am in a small town when you have a wheel bearing weld itself to the spindle, because a buddy never checks them ...LONG STORY....)<br /><br />quick condensed directions:<br /> I would jack up the trailer. Remove the hub assy. (if you take out the front bearing and washer, screw the nut on, and pull out and downward on the hub you will remove the back bearing and seal....less work (IMHO) then prying out the seal to get it off). You can replace just the bearings (not the inner part) provided you haven't had any problems. Pack the new bearings with gease (have someone show you...there is a little trick). Install the bearings with a NEW rear seal. set your preload on the nut (I tighten it tight, spin the wheel, then loosen it till the wheel spins freely, but not wobbly... There are 15,000 ways to set the preload and ou will hear other ways I'm sure), Install the cotter key (or what ever lock it has).<br />Install bearing buddies and you are done.<br /><br />These are general directions, you set up may be a little different so note how you take it apart.
ThomWV
