viperbluelx
- Joined
- Mar 23, 2011
- 16
05 Stingray 185LX with 3.0 Mercruiser.
If I run around with the trim fully down or very close to it then the boat runs smoothly across the water, if I trim up to where the MPH picks up and the engine sounds better than after a few seconds the front of the boat will start to slowly hop up and down in the water like you're hitting wake over and over, even though the water is smooth. I can put the trim back fully down and the boat smooths back out. I have no idea why it's doing this or if this is just normal? I just bought this boat this year and the first time out I ran up on a sand bar and messed up the prop. I'm not sure if this issue has to do with that or not? The prop is new.
