When running the engine with muffs, how long should I leave the water on after..
ShawnQ
After I have been running the engine on land with the muffs on it, I was curious if it is possible to turn the water off too soon after you have killed the engine.<br /><br />For instance: Let's say I am setting idle, the engine is at normal operating temps, and when I am done...I kill the engine. <br />Is it OK to instantly turn off the water hose/flow to the engine, or should I let the water run a little longer? <br /><br />Just curious...this is something I was never taught.<br /><br />Thanks!<br />Shawn
JB
Re: When running the engine with muffs, how long should I leave the water on aft
Hi, Shawn.<br /><br />First: Do not set the idle on muffs. There is no back pressure on the exhaust system. Your idle will be off when she is in the water.<br /><br />You can turn off the water as soon as the engine is shut off. That is when the water pump stops.<br /><br />Good luck. :)
ShawnQ
didn't even think of that!<br /><br />I didn't really set the idle, I basically adjusted the throttle linkage today....so that it would idle with the throttle totally off/closed.<br />Didn't touch the carb settings...<br /><br />Thanks for the input though!<br /><br />Shawn
