BrettBBonner
- Joined
- Jan 1, 2003
- 5
I have a 1990 ski-boat with a 175 (4.3L) Mercruiser Alpha 1 I have owned since new. It has 400 hours on the engine and running only synthetic after 1993. Wasn't running well, ran a compression test and it failed on CLY 2-4-6 with 130, 90, 90 respectively. (when the plugs were pulled and water spurted out, good indication there was a problem!!!). Pulled head and found bad valves on 4 and 6 and a bad head gasket between 2 and 4, and some water - not much - in oil. The gasket could have been leaking water into cylinder 4 and into the oil. I Put a dial indicator on the pistons. Piston number 4 is about .004 to .007 below the other pistons at TDC. I?m assuming a bent rod, although I really don?t know what the spec is. Cylinder walls look great, no rust, no piston ridge ring. Engine has a new alternator, starter, fuel pump, one relatively new exhaust manifold. Took the heads to an engine shop and two sets of valves on both sides would not hold vacuum.
One other complicating issue ?The glassed-in wood under the motor mounts I should pull the engine anyway as I need to cut out and re-glass in some engine mounting wood. It?s all temped up now with injected epoxy wood flour and might hold forever. I'm doing all the pulling of the engine and the mounting on the long block, but my time is worth something.
Questions:
1. Is this rod bent enough to REQUIRE a bottom rebuild or rod replacement.
2. If I test the exhaust manifold and riser with vacuum and they hold vacuum, should I replace anyway (they are 20 years old).
3. Should I
A. Install a new 220HP MPI for about $6.5K, which is a complete engine with manifolds, engine coupler, mounts, etc.
B. Put in a rebuilt long block with new manifolds and risers for about $3K
C. Take a chance on a head job and gasket kit for about $500 and hope the rings are still good and the water in the oil came through the bad head gasket or some minor blow-by?
I'm only using the boat maybe 20 to 30 hours a year now because I'm getting older and I have other boats. But I might have grandchildren someday and my kids might use it more in the future.
Any advice is greatly appreciated.
Questions:
3. Should I
