when to replace t stat?
coolguy147
well i know a impeller is abotu evry 2 years but what about a t stat? do u replace it with the impeller? dont they usually last longer then that
pvanv
Re: when to replace t stat?
Thermostats can fail (jam) either open or closed. They usually get replaced if there's either an overheat issue (stuck closed) or cold plug fouling (stuck open). Other than that, they are not usually "routine maintenance" items. We usually check them if we're replacing an internal anode, which is often located near the thermostat. They can be tested in a container of water on a stovetop, with a thermometer. The manufacturer will have a "start to open" temperature, and sometimes a "fully open" temperature. If in doubt, test it. If bad, replace it.
tashasdaddy
fresh water they can last 20 years or more. salt water i change every time i do the water pump. just cheap insurance.
