Dandydan
- Joined
- Jul 27, 2018
- 34
Volvo Penta DP C1 290 5.0FL PMDA
This is probably a dumb question but here goes anyway. I was recently running my engine on ear muffs and decided to go check out the flow into engine. I climbed out of the boat and discovered there was no water coming out of the exhaust ports. I immediately jumped back into the boat and shut it off. The temperature gauge when I shut down was just starting to get above what is normal. My first thought was that the raw water pump impeller was shot needing replacement. No big deal, it was due anyway. Ordered the part and pulled the pump and did the replacement. I discovered the impeller was worn but not broken or disintegrated. So I got to thinking, why no water coming out of exhaust ports. I decided to check if water was getting to the pump so hooked up the muffs again and watched as my wife turned on the water. No water getting to pump. Next I disconnected the hose from the fitting just inside the transom shield and turned on the water again. No water coming in. After reconnecting the hose to transom shield fitting to power steering oil cooler
