Where are idle adjustment screws on Chrysler 60?
Fenderman
I have a mid 70s Chrysler 60 with two Tillotson carbs. The factory manual says to turn idle adjustment screws on carbs to set idle, but shows no picture where these screws are and I can't seem to find them. Can anybody help me? Thanks.
eurolarva
Re: Where are idle adjustment screws on Chrysler 60?
look above the choke on the carbs. On the upper face you will see a slotted screw just inside the carb. That is the adjustment. The pic below is not for your motor but you can see it part number 15. This carb is real similar to yours.
Fenderman
AHA, inside the carb...never thought to look inside. Now I see it, thanks.
jerryjerry05
That # is the air screw not the idle adjustment. The idle is controlled thru the linkage.Jerry
eurolarva
Man I am sorry. I guess I misread or assumed the idle mixture. Here is where the screw your looking for is
jerryjerry05
Now you got it!!!! Now where did you get the pics? Jerry
