I noticed I was getting water in my tilt/trim fluid over the summer and when I brought the boat home for the winter I decided I was going to reseal the cylinders. When I pulled the first cylinder apart I believe the cap (not sure the actual name) was installed backwards in the tube and pressed itself over the 9/16 bolt going into the end of the shaft and broke the washer that goes on top of the 3 springs. I believe the washer is the only piece that is damaged, but i cannot find anywhere that sells them individual. The seal kit I purchased does not include them. I will attach a few pics of how the cap was on the end of the shaft and of the washer.
