Where can I find this part?
RS Advertising
I've recently purchased a carb rebuild kit for my Volvo Penta 4.3 GL PEFS and the part indicated in the attachment isn't included.
Unfortunately, this is the main reason I ordered the kit as mine has broken in two!
I'm based in the UK and cannot find one anywhere.
Ideas??
Fun Times
Your carburetor will be a Holly though the exact number escapes me at the moment but the red rubber looks to be called a rubber vent but it seems they have a few sizes so knowing your holly carb number should help narrow the search for the correct size.....That mentioned you may be able to find a local high performance auto parts supply place that sells Holly parts/kits and find one there.
Manufacturer Part Number : G797 = 5/8 inch, http://www.carburetion.com/Products/...aspx?Part=G797
Manufacturer Part Number : G603 = 1/2 inch, http://www.carburetion.com/Products/...aspx?Part=G603
^ plus a few other sizes as you scroll down and click on the other vents.
http://www.carburetion.com/sitesearch.aspx?category=Holmisc&Title=Misc for Holley Carburetors
http://www.carburetion.com/holley.asp
Rubber accelerator check valve
Available anywhere in the world they sell holley carb parts (speed shops, internet sales)
Funtimes has the part numbers
Very important. When you pull the check thru the bowl casting by the ***, cut off the extra length of the *** off or it will hang up the float
If you need, in a pinch, you can reuse yours if it is still clan and pliable
RS Advertising
You guys are amazing..
I was just about to bite the bullet and order a whole new kit but you've saved me!
Thanks very much
