Where can I get a primer?
bandman72
My 15hp force has a primer on the front of the motor. It doesn't work, the inner rubber membrane has disintegrated. I can't seem to find the part on iboats......I believe it's a 95 force 15. I can't seem to get any of the serial numbers to match up with anything. Here's the numbers I can find....
Mod: 225 581 501
Ser: 4752
Then there's a R575834
Thanks for the help.
roscoe
Re: Where can I get a primer?
Mercury part number F681046 BULB-PRIMER $17
Available at any Mercury dealer.
This is for the primer bulb only, not the cover that goes over it, the cover is no longer available.
Your motor is not a 95 model, they didn't have a primer on them.
Serial number would indicate a late 1980's model or early 1990's.
The good news is that they all used the same primer bulb part.
