1989 Cobalt, alpha one, Gen 1. Had the upper and lower off this winter for a serious paint restoration. While I had the u its apart, put new revile water pump kit. I put the upper unit back on the boat first. Shifter was in forward gear. Then put the lower unit on, lower unit was in forward, and for some reason it was a stickler going back together. Shift rod seemed ducky, after I started it on the trailer with muffs, shifted perfect.
Today we finally put it in the water. Engine, 350 Chevy, starts right up. Put it in forward idle. No problem. Put it in neutral and then again in forward, a,d nothing happens. Can't for forward or in reverse. Go over the side, raise the unit, shift rod and shift over are not together, screw around get them lined up. Get in, we have forward gear, head towards dock, when I go to put it into revers, I am still in forward. Crash....
Need a little help on this one please. Afterwards, when I went to get the trailer, someone was not paying attention and crashed into my trailer. Naturally the wife is yelling at me...need to put her on a sail bote!
