62cruiserinc
- Joined
- Oct 30, 2009
- 295
I was reattaching the outdrive (Alpha 1 Gen 1 SE106) to my 1981 Sea Ray. After pushing the drive shaft through the gimbal bearing, I went inside to see how it was lining up before pushing the splines into the coupler. I saw the splines just about to enter the coupler, with the following rubber ring hanging from the splines:
Where did this come from? It looks like a grease seal minus any metal frame and it's labelled Mercury 26-88416. It came from somewhere between the gimbal bearing and the coupler.
My driveshaft has the usual 3 O-rings for sealing the shaft.
The original outdrive on the boat was an MR-1, which was replaced with the SE106. Is this seal something left over from the MR-1 drive setup? I don't see where it would do any sealing with the current shaft.
Thanks
Steve
Thanks
Steve
