i have a 1991 5.7 350 v8 i pumped out the engine oil and changed the engine oil filter where do i add the new engine oil ?? thru the pcv vent hole on the valve cover????
Are you kidding? pour it into the rocker cover with the oil fill neck, if it doesn't have one than through the pcv grommet should work, you can funnel it down the dipstick tube if you have patience.
