Where do I get a wiring diagram for an 85 hp johnson?
outboards115
Can anyone sugest some web sights that I can get a free wiring diagram for my 1971 85 hp johnson? A person I know gave this outboard to me, he said it "I've had it running", but all of the wiers are corroded so I need to find a wiring diagram to fix it. If anyone can help me it would much appreciated.
Mikeyboy
Re: Where do I get a wiring diagram for an 85 hp johnson?
Not sure about a free one but one of the best investments you could make in your motor is a service manual and they have the diagrams in there. Check outboardbooks.com
N1NE1
does it have an alternator? if so send me your email and i will try to get it to you
F_R
All 1971 85hp Johnsons have an alternator.
outboards115
When you say alternator, do you mean the charging system under the flywheel?
outboards115
Sorry, I mean the stator.
buckeye_paul
outboards115
Hi,
thank you N1NE1 for sending me that diagram. Its helped me so much!
Also thank you buckeye_paul.
Still working on it, but with school in the way it might be a little while yet.
outboards115
hi,
is there any way i can by-pass the red plug and still get the motor running because the one on my 85 johnson has been cut off and trying to work out how to start it.
outboards115
hi,
For that matter, is it eaven possible?
Joe Reeves
NOTE: This engine IS NOT a 1971 85hp model Johnson..... IT IS a 1977 85hp model Johnson! DISREGARD all and any posts/replies pertaining to a 1971 model! (Edited 05/15/12)
hi,
Hmmmm... Wondering why anyone would cut the main electrical plug off. Is the plug missing from the engine wiring harness or from the instrument wiring harness that would plug into it? However....................
Rest of message deleted.... pertained to a 1971 85hp model (error).
outboards115
thank you joe reeves,
the red plug is cut off on the engine wiring harness, dont know why. but I'll give it a shot!
And also you said "Run a small jumper wire from the positive (+) side of the battery cable connection at the starter solenoid to the wire that supplies voltage to the pulsepack at the terminal strip. (Supplies power to pack/ignition)" what colour wirre/s would that be?
outboards115
Hmmmm... Wondering why anyone would cut the main electrical plug off. Is the RED plug missing from the engine wiring harness or from the instrument wiring harness that would plug into it? However....................
Hook up the battery as normal to starter solenoid and powerhead ground.
Make absolutely sure that the throttle is only slightly open. You do not want that engine to start at a high rpm!
Another small jumper wire from the positive battery cable at the starter solenoid to the small 3/8" nut terminal of the same solenoid will cause the starter to engage and crank the engine over.
You can run another jumper to engage the choke or operate it manually.
If the engine starts and runs, you can stop it by simply disconnecting the small jumper that leads to the pulsepack. (Eliminate the ignition)
Make sure your life and hospitalization insurance is paid up!
hi,
I tried jump starting the engine like you said, but no luck and when and you say "pulsepack" is that the reflicter? If you can, can you show me a picture of one, so I know if my motor has one. That would be much apreciated.
Joe Reeves
hi,
No luck with what? Cranking the engine over with the electric starter OR having the engine actually start? Be specific when possible.
outboards115
Hi,
I had a bit of trouble cranking over the engine withe spark plugs in but when they were out, it was fine but couldn't get ingition from the spark plugs. didn't eaven get a small shock from them when I put my finger on them, but I think I hooked up the wrong wire. I hooked up the red wire coming from the reflictor to the plus side of the solenoid. But thanks any way I'll give it another shot today.
outboards115
Hi,
you said "The voltage supply wire would be "purple". Is that wire comeing strait from the powerpack or tose that wire go to the terminal block and then come out? Also if that dosent work is there any trouble shooting methods you can suggest. Thanks.
Joe Reeves
Message deleted.... pertained to a 1971 85hp model (error).
outboards115
Hi,
I dont think the powerpack has been replaced, it looks pretty orrigonal. there are no purple wires coming from the powerpack but there is a purple wire coming from the terminal block. Is that the wire your talking about?
