gemcitypos
- Joined
- Sep 23, 2008
- 20
I have a '94 Maxum 20.5' Runabout with a Alpha 1 Gen II 1.84 Ratio. I purchased this boat after it was REPO'd. It had no engine but originally camewith a 4.3 LX. And the outdrive had a 21 pitch aluminum prop on it.
I have repowered the boat with a 5.7
I put my brothers extra 23P SS prop on it for testing today with what I think are strange results. Bear in mind this is my first boat.
With only my 17 y.o. son and me in the boat it took till about 3000 rpm for the boat to plane out, then I could cruise at about 4000 rpm. I think I was only going around 25 (Speedo Busted). I could never got to WOT because the stick was only around 75% when I hit the 4800 max rpms. One time I accidentally put the stick down and I think the rpms went to around 6500 rpms but can not be sure cause I backed it off real fast.
I know the outdrive ratio is not the recommended ratio, but I have been told (Merc Dealer)I should be able to handle this with a new prop.
Any Help is appreciated. Thanks in advance for all the great Info.
