For an easier install I like to put the ring on the out drive during the reinstall, the boot will be hard enough to set correctly, you don't want to worry about crimping the o-ring too.
In most cases it is never removed until the boots are being replaced
I am surprised by this. I replace it along with the gasket (#15) everytime I remove and install the drive. I am curious what others do.
Not to be contrary... but no. It is much easier to use some bellows adhesive and glue the big square rubber ring in the bellhousing, then install the drive.
he handed me the gasket and it didn't have one in the bag. The old seal was still there so didn't give it much thought
When working at the service shop this kind of seemed more dependent on the situation of what one was doing to the boat service wise. Those O-rings seemed pretty hardy/sturdy if you will and seemed to last a decent amount of time. Depending on their overall condition, know age, fit and what was being done as far as needing to take the drive off for inspection and/or water testing up to possibly a couple of times or more, some dealers would buy new bell housing gaskets in bulk and save the full gasket kits for full annual or known final testing service jobs since the gasket was the weak link when removing the drive as it seemed to often tear apart someplace no matter the age or times removed. Yes it's always better & safer to replace with the whole kit during annual full service jobs just so to be on the safe side but there are just some incidents where it may not totally be needed if you're careful about everything in order to get by okay.I am curious what others do
