fishhunter
- Joined
- Feb 24, 2002
- 86
Hey fellas, i have an old 79 challenger fish/ski that takes on water.I put the plug in and ran the hose in the bilge and and saw that some water was leakin out around motor mount (outboard,merc 200hp) i noticed there was a hole filled with silicon that apparently was the result of a bad measurement when the tilt/trim was installed (didnt line up i assume) the bottom of the boat looks fine watt i can see of it on the trailer except for a couple small chips in the gelcoat, which ive learned here can let water wick in,iam not too concerned about the looks of a patch job , so could i just use a little epoxy on those littl places? or should i use gelcoat?Is that something a novice can do? all iam looking for is to stop the leaks,and keep my transom from rotting off
