where is My Depth Finder Transducer?
uncwgrad1
I have a 2003 SX-195. I was wondering where the transducer is located for the depth finder. Is it a thru-hull glassed in somewhere?
brick75
Re: where is My Depth Finder Transducer?
Unless you see it mounted on the transom, it would be a thru-hull design. I believe they're generally mounted as far to the rear as possible and as close to the centerline as possible, so I'd just look around that area under and in front of the engine for it. Shouldn't be too hard to spot.
uncwgrad1
Thanks! I'll take alook when the weather clears!
