Where is my thermostat ?
cloumar
As I was replacing the impeller and the thermostat on my motor - Force 75 HP - 1998 - I found the thermostat housing empty and it looks like it is from day one - no thermostat in it. I went to the Merc. dealer and the guy said as per the serial number of my motor there should be one in it - have you seen something like this before ?<br /><br />Thanks<br /><br />Smoky ;)
ob
Re: Where is my thermostat ?
Did you buy the motor new?
cloumar
Well OB,<br /><br />I bought the boat used last year and the motor on it was installed in june 1999 and it didn't run very much between 99 and 2002.
ob
I'm guessing the original owner removed it.
cloumar
But with your experience, according to you is it better to have one in there or it doesn't matter ?<br /><br />Thanks<br /><br />Smoky
ob
Definately.Put one in .This enables your engine to run at the designed temp and also provides quicker warm-up.
