Where is the data plate on an old outboad?
Wingnutt
Might as make my first post here a question. I acquired an old (62?) Starcraft that i an refurbishing to be my winter fishing boat. I'm now to the point of wiring up a new ign. switch. The trouble is, that the previous owner cut the old one off. I "think" the motor was made for Montgomery Wards by Chrylser (that is what is on the control box for the throttle and shift selector) and after a little research decided that it was made around 1970 or so. I need a schmatic (sp?) to correctly wire it, but first I have to know what year it is. Hence my question. Where do I look to find the manafacture's data plate? I've looked all over the motor and can't find it anywhere. TIA
roscoe
Re: Where is the data plate on an old outboad?
Usually found on the transom mounting bracket. You may have to tilt the engine up to see it.<br />Also check the block (powerhead) for the serial number, which may be stanped into it.<br />Lastly, look at the top of the powerhead, near the thermostat housing, for a small aluminum cap. It may also have the number on it.
