Where is the fuse panel/block on a sundeck 217
pbolden
Hello Everyone,
I looked under the helm and saw everything else but the fuse block. Is it located somewhere else? I'm going to be installing a VHF radio.
Thanks,
Paul Bolden
NelsonQ
Re: Where is the fuse panel/block on a sundeck 217
Paul
I'm not familiar with that particular boat however each switch on the Hurricane have a breaker and therefore there is no fuse block installed (each circuit is individually protected by the inline breaker)
You can either install an inline fuse, breaker, or add a fuse block for future uses as well.
Ernest T
Paul
+1
On my 2010 217SD there are push button breakers below each switch. There is at least 1 or 2 extra unused switches that could be used to add devices on my boat.
pbolden
Thanks NelsonQ and Ernest T.
Paul Bolden
billdewberry
On my Hurricane 201 Fundeck there is also a breaker, but there are fuses on the battery which controls the Stereo and other electronics. Also behind the dash is on glass fuse that if it blows none of your gauges will work. I know because I spent all weekend running new wires.
NelsonQ
Bill
That's correct. I had the same setup on my 2002 170GS, however in around that time, they started switching their panels to full breakers and no tube fuses. I know the 2002 Fundeck 226 had breakers as that is the same boat a friend has. What year is your boat?
