Where is the high speed needle?
josh_scci
Can someone point out where the high speed needle is so I can check to make sure they are not plugged while ive got it tore apart to replace the fuel lines.
Monte1961
Re: Where is the high speed needle?
what are we working on? post back
josh_scci
1985 40hp Johnson same one you helped me with last night. Also did you check the other post to see what you thought of what I found?
Monte1961
No i did not ill look. can you give me the model # of yer OB?
Monte1961
If you look at the carb, is there a small tube about center of the carb that looks like it goes into the float bowl?
Monte1961
Part # 7 would fit around it!
josh_scci
If I understand correctly then I cant access that without disassembling the carbs?
Monte1961
Caution::::::::::::Do not remove that tube, and if it looks bent, don't try and straighten it, It's supposed to be that way! Good luck and post back results. Monte
josh_scci
OK. So what are your thoughts on what I found today in the other thread?
Monte1961
Well if it has any vacuum leaks or dripping fuel, it won't run right. So if the carb/s haven't been overhauled in the last year, then it's time anyway regardless. Good luck and chime in anytime! Monte
josh_scci
Well thats the thing they where overhauled last year by a shop, but I guess they only did what had to be done. I know they did it because it didn't run at all before it went in and it has only been on the water about 5 times since it was in the shop. I think I will try and replace all the fuel lines and block the VRO of correctly and see what happens. I'm just afraid I may get in over my head if I try to take the carbs off to work on them.
BC Coaster
I had a problem with my 1986 55 super, #19 is the high speed orifice, mine was plugged solid.
you have to remove the screw plug or fuel hose fitting first.
