Where is the motor fuse on a Tohatsu M90A outboard?
papajoe61
I accidently hooked up my battery in reverse and sparked. Ever since then it will not turn over, so I need to find the motor fuse. I've looked all over under the motor cover. Is it outside of the motor in the boat wiring or under another cover inside the motor? Please attached a picture or diagram if you can help me.
Thanks in advance.... Joe
pvanv
Re: Where is the motor fuse on a Tohatsu M90A outboard?
It's in the wire that runs between the battery cable at the solenoid and the start wire of the RC box.
