Hello! We have a 2016 Hurricane boat, and discovered water leaking out of the corners transom trim pieces. The water is not usually as much as it looks in the pics; these were taken just after a rain and I had slit the caulking to let more water out.
We are trying to work with a repair shop but it seems there is an indefinite timeline of when they will get this submitted to the manufacturer for approval to work on this and many other warranty items.. they are waiting on a contractor to estimate one set of items and they can't seem to get the guy to get it done and it has been a month. they won't submit the order without this other set of items for some.. I have tried.
I noticed that the aluminum trim piece under the engine was warped up a bit, and they sealed that up thinking that was the problem. It rained the next evening, so the caulk had just a bit over 24 hours to cure.. I do not know what type of caulk they used or how long it takes to cure. I noticed when I got home that they did not seal it perfectly, so I did my best to fix it, and that did not seem to fix the problem. Now, it looks pretty well sealed to the eye, even so. Maybe somehow it is still not sealed up perfectly, but I am just not sure
After it rains, water is still leaking out the trim. I have also been taking a shopvac to the bottom trim corners after rain.
Also after we got it home, I noticed they also did not re-caulk the starboard side corner of the trim, and that is how I realized quickly that it was still getting water in there because it was leaking out after it rained. It needed to be re-caulked because I had slit the caulking in the bottom corners so water can run out.
Unfortunately, our options for who we can use for warranty work is limited in our area. We already had an awful experience with one and things are not off to a good start with this one based on this and the fact that one of their employees caused damage to our boat while backing another boat in next to ours. They are going to fix it but who knows when!
I really hope things turn around!
Anyway.. any thoughts on what could be causing this leak? I just want to get this figured out and fixed so I can enjoy the boat, not worry myself sick about my boat rotting out, and not have to spend my evenings after rain storms with a shopvac to it.
Thank you in advance for reading, and for any thoughts you provide!
