I have a 1979 Evinrude 40 hp motor that has water running out from under a u shaped bracket. This bracket bolts around the back of the motor shaft and bolts to the bracket that holds the motor to the transom. Is this normal? Good stream of water coming from pee hole and through prop housing. Motor is hooked up to garden hose through a muff.<br /><br />Thanks in advance for all of your help.<br />Larry
