Where should I start
mcdanalt
Evinrude 65 HP, Model# 65373R, Serial# J011841<br />I think this is a 1973 model.<br />I got this motor off an old boat. I hooked a battery to it turned the key nothing. The choke toggle worked. Is there a safety swtich I'm missing? I did jump the starter, it works. Carbs probably need cleaning/rebuild. The spark coils are cracked. It seems to have good compression and the lower unit seems to be in good shape. The control linkage are functional. Is there a service manual and parts avaiable for this motor? My big question, is this motor worth the effort?
rickdb1boat
Re: Where should I start
There are parts and Manuals available for your motor. But first thing you want to do is check the compression to see if it's worth putting money into. You can pick up a compression tester at most auto parts houses pretty cheap. find out how the compression is and let us know...Might want to read this, too;<br /><br /> web page
mcdanalt
I did check the compression. All three cyliders were between 110 and 120 psi cold with the throttle shut.
ledgefinder
Ensign
Right - 1973. Great motor, in fact one of the best with gas going up the way it is. Make sure you prop it to let it wind right out though. The early looper triples like yours produce 65/70 hp from only 50 cubic inches; as opposed to the crossflow V4s 85-140hp from 94-100 cubic inches. In other words, they're highly tuned, and don't like to be lugged. Really good motors though. <br /><br />OK, there is a safety switch that keeps the starter from working if the throttle is advanced much at all. It's over on the opposite side of the block from the starter, by the throttle pivot (if I'm remembering where the triple starters are correctly). It works a little counter-intuitively if you're used to a car. The far end of the solenoid is grounded through the safety switch. If the switch allows a ground, the solenoid activates and the starter cranks. If the throttle's open too far, the switch opens and doesn't allow the ground, and the solenoid can't activate. So...just ground the wire from the solenoid to that safety switch, and try the starter. Work OK - good, that's your problem. If not, post back.<br /><br />Prop that motor so it turns a good 6K with just you in the boat. Probably a 13 or 15" pitch prop, wildly guessing at your boat size. Clean the carbs & put a new impeller in it (unless you're sure the impeller is recent) - those are the three weak links. Change the lower unit fluid, putting new gaskets on the two screws. The fluid should not be "milky" (means it has water in it), not have much in the way of metal in it. Some fine metal filings clinging to the magnetic drain screw are normal & OK. <br /><br />That's an unusually good motor - I'd hang onto it.
