Re: Where to buy NEW GM engine
Just an FYI: I caleld my GM parts guy (local car dealer) and he told me, "As long as you can get me the part number I can order anything GM makes". Put that in the "for what its worth" department.
Likewise, I was always able to get any engine.
Well guys, i looked through my old stuff from a couple years ago when i helped a friend do this...
Here is the part number 620-57320V, its a new not reman, 98-2002, 295 hp, vortec, marine, long block. It was at the friends insistence, for the sake of time/good quality, that he use OEM crate. I would have taken the time to assembled my own.
If you check with your local GM auto dealer parts guy he will likely tell you that number is no good! He will also say that his system has no Marine engines in it and it must be the same as a truck engine... Which is not far from the truth! Some are very close!
If you call a large large GM engine dealer like Scoggin Dicky, probably the largest in the country, They will politely tell you that they have access to some assembled "Marine" heads but do not to sell the marine long blocks and will encourage you to call a "marine" dealer. If you don't believe me try, if you say you can
than call and report a price & post the part number and dealer name!! I'm sure the o/p would appreciate it.
