Where to fill up my tilt/trim motor? (Photo Attached)
river_bouy
Hi,
I have an '84 Suzuki DT50 and was wondering where to fill up my tilt/trim motor with ATF fluid? There are two phillips head screws on the motor (as seen in picture). Do I have to take them both off and then fill from the bottom (same as doing the outboard gearbox oil)?
Thanks in advance
BaileysBoat
Re: Where to fill up my tilt/trim motor? (Photo Attached)
The lower screw is the fill plug. Don't remove the upper screw, looks like it holds the motor windings. You probably fill with the motor tilted fully up and secured by the tilt lockout lever. Check it out here;
http://store.brownspoint.com/dt50.asp
river_bouy
Thanks BaileysBoat, just what I was after.
