where to find a fuel pump assembly diagram
Danny C
Quick, help please.
Got down to Kentucky lake yesterday for a family weekend at Kentucky Dam Marina. Anyways, I spent 2 hours yesturday trying rebuilding and then replacing my fuel pump. I am pretty sure I am not assembling all the gaskets in the proper order. I have a 1983 merc 115 stacked 6 cylinder. Anyone know where to find a diagram on how it goes together?
Additional info: not getting fuel into the cylinders. if I squirt fuel into carbs it will fire. thought it may be carbs but when i disconnected fuel line to carbs and cranked it it spit very little fuel. I can use primer bulb to push fuel through just fine but pump wont pump it. I just learned that vacuum from cylinders actuates pump so I will check that as soon as it stops raining. I dont think i have a gasket inbetween housing and cylinder...now i am wondering where in the assembly i put that gasket.
Thank You for your help.
Chris1956
Re: where to find a fuel pump assembly diagram
Punch up the crowleymarine.com parts site for the parts pictures and numbers. There are a couple of different fuel pumps, however, all will allow you to prime carbs using fuel system primer bulbs. Parts are avail most marine-type places
Danny C
Thank You Chris1956 I will check that site out. Also decided that I need to rebuild carbs after seeing all the junk in the fuel pump and previos owner did not have a filter, so that is on the list too.
