Re: where to get parts
If I'm picturing what you're describing right, it sounds a little different from what I made. Mine was round, about 1" long with both ends flattened to fit the slot in the sproket thing that the throttle cable turns. I simply used a hacksaw to cut the flats in both ends. A grinder probably would have been faster.<br />In retrospect, a peice of aluminum rod would have made much more sense to start with. I suspect it was probably a Sunday when I made it and I already had the bolt.<br /><br />But I bet you could get it from one of the places Rick has above for like $2.
