Re: where to mount transducer
Are you certain you read the instructions correctly. If the transducer interferred with the prop that would mean the prop strikes the transducer and makes it into little bitty pieces. Those instructions probably read - install the transducer so the prop does not create turbulence that can affect the transducer. You mount the prop on the right side of the boat as far from the prop as you can, and not in line with any strakes, lines of rivets, or other obstructions on the bottom of the boat. Transducers cannot read through air bubbles so they need to run in relatively smooth water. Close to the prop is turbulent water which is what the instructions were getting at.
