Where to put Lewmar Windless Selenoid
viper1216
I am installing a v700 in my boat. Got everything installed and am buttoning up the wiring. It has a 35a breaker that I need to install near the battery per the manual which is in my engine compartment. Where I am having an issue is the wire connections are on the back of the breaker, so I can't just install it flush against the hull or something. It would need to have a big hole for it to go through and then the wires come around into the back. Not ideal. Is there some sort of electrical box or something I can get? Mount the box and put the breaker in? Sort of liek an outlet box you would put in a house, but smaller. Should I look and see if I can find a different type of breaker to install that has a different connection? I've seen some that are all on the front. Boat is an 01 Maxum 2400SCR. I don't have any other breakers anywhere on the boat to install it anywhere accept my 110 panel in the cabin.
Mine are mounted on the side bulkhead in the engine room. Might want to just get another breaker. The water proof ones are nice
Mine goes from the Bat to a main solenoid used to turn ON the windless. Then short cable to the breaker, then to the windless solenoids near the windless
viper1216
Yeah, I think that is going to be the best thing for me to do. What you have is exactly what I want for a setup. I watched a setup video for it, and the guy had one like yours. I'm thinking the one they gave is more for boats that have a breaker area on their boat. Mine is only 24' so there isn't anything like that on board.
