wheres my spark
pleaseaddwater
i have an 88 bayliner with an 85 hp force..it used to run great...now not...itll crank all day long and not start...sounded like it wasnt getting spark...so i took the wires and boots off and tried to make a spark by holding it next to the block and no spark out of any of the 3...i already replaced the flywheel key and cleaned off the stator and inside flywheel....any sugg? :confused:
pleaseaddwater
Re: wheres my spark
i also stuck my volt meter on all the wires off the power packs seperatly and got no reading...dont know if that matters....
dsujen
Re: wheres my spark
Check your ground and power connections and wires. Make sure they are good and clean. I just bought a 97 harley that would sometimes start. It turned out that the positve wire from the battery to the starter was broke from corrosion. It was shrink wrapped and looked clean on the outside, but it was completely corroded through. If all 3 aren't firing and the wires and connections are good, I would think its a power pack or coil problem. I'm new to boat motors so don't depend soley on my info.
pleaseaddwater
Re: wheres my spark
thanks for the advice but its cranking so its getting power but not spark from the coils...also i looked around at other threads and tryied to reground the coils and packs and that didnt work either...would the stator keep them from sparking or hell i dont know
dsujen
Re: wheres my spark
I don't think the stator has anything to do with spark. I thought it was strictly for the charging system. Check your service manual and look at the wiring diagram. There might be some kind of pulse generator or and electrical component that is bad before you get to the power packs or coils.
