I just got done replacing my u-joints on an '88 OMC Cobra 5.7. After getting everything put back together I went to grease the u-joints with Merc U-joint / gimbal grease. I can tell the u-joints filled up with grease as it got progressively harder to pump, but I can't get grease to oooze out of anywhere (like I expected it to start oozing out by the base of the caps) However it has just gotten about impossible to pump anymore grease. I noticed the caps fit into a rubber lip at the base, which I am guessing is not allowing the grease to push by. Is this normal? Or should I be able to pump enough grease to eventually see it pushing out at the base of the caps? Thanks!
