Where's the Water Pump Outlet?
gprocks
I just picked up a 1982 Evinrude 2HP model E2RCNE and it runs great, very clean, almost showroom condition. I notice when I run it I cannot see any water stream from the head for cooling so I have a new impeller on order.<br /><br />However, I cant even seem to locate the hole where the water would come out of and picked up a service manual which doesnt mention it either.<br /><br />Does anybody know where to locate this, or by some miracle, does the water not stream out of the head as in most engines?<br /><br />Any help would be appreciated.<br /><br />Cheers,<br />GP
DHPMARINE
Re: Where's the Water Pump Outlet?
GP the water exits thru the exhaust/driveshaft housing.Above the plate just above the prop.<br />DHP
gprocks
DHP,<br /><br />Thank-you, that explains why I can't see an exit hole on the head.<br /><br />Cheers,<br /><br />GP
BF
on my 2hp, it was a fine mist from the exhaust holes at slow speeds, but noticably more after the impeller change.... so for the few bucks, it's probably a good idea to change it out anyway. Also, you might wanna pick up a couple shear/drive pins to carry as spares.<br /><br />Brent
