agallant80
- Joined
- Oct 25, 2010
- 2,328
Bravo3 in salt water. She lives on the trailer for now but will be slipped shortly.
Aluminum?
Zink?
Other?
Aluminum?
Zink?
Other?
That may be true if the out drive and anode where the same aluminum alloy, which they are not.Crap, your outdrive is aluminum. So you want to protect it with the same metal?
| Zinc Anodes | Aluminum Anodes | |
| 355 Ampere hours per pound | 1225 Ampere hours per pound | |
| This means a Zinc anode will give one amp for 355 hours for every pound of Zinc | This means an Aluminum anode will give one amp for 1225 hours for every pound of Aluminum | |
| Take a typical Z3 (weight=4.68 kg) as seen on page 47 Total ampere hours 3656 | Take a typical AZ3 (weight = 2.7 kg) as seen on page 47 Total ampere hours 6125 | |
| Assuming the anode performs at 0.5 amp | Assuming the anode performs at 0.5 amp | |
| This anode will last for 7312 hours | This anode will last for 12250 hours | |
| Which is 304 days | Which is 510 days | |
| Which is 10 months | Which is 16.5 months |
