which bass boats dont contain wood?
ive been having a blast in a old bass boat i bought and now i know what i want in a boat its time to start looking for a new one. at what year did they move away from wood on the boats or are the new ones still using wood.
robert graham
Re: which bass boats dont contain wood?
Check Triton Boats, very nice all-aluminum bass boats...probably several others I'm not aware of.
sankanother1
Glastrons and Larsons with the vec construction but they had their own problem..Blisters and its big bad deal too.Caravelle Is a great boat and 2003 seems to be the magic year.But not all the models switched over in one year so find one and make a call or google it. Great looking boats too.
haulnazz15
I'm not sure those are considered "bass boats". To the OP, you might have to search the bass finishing-type forums and see if you can't come up with an answer if no one here knows. The problem with composites is that they tend to weigh more than wood, which slows you down. Bass boat mfg's don't like sacrificing much speed. Check out triton, ranger, champion, heck even Nitro and see if they have any specs on their websites.
sutor623
I have a 1976 Fiberking Bomber Citation that has fiberglass stringers, and only 1 main board down the center. Then the foam is poured and 1/2" marine ply is set on there before it drys. So really, no wooden stringers. It is a 17' trihull and with trailer and no motor weighs in at an incredible 1500lbs.
Some have different definitions of "bass boat." Glitter club? Tin club? Low and fast club? Lake lounging club? Are you looking for something you would see in the FLW tournament?
sschefer
Last i heard the Allisons had no wood.
Philster
Allisons have a bad rep when it comes to hull integrity/strength. They might have no wood, but they don't build non-wood composite hulls very well.
Having zero wood does not = better. The most advanced builders can handle 100% non-wood boats, but they are the big boys building big center console boats with big $$$ price tags.
Might be harder to find smaller, modest builders who crank out well-built, non-wood composite boats.
wtxmale
Ranger Bass boats have no wood,,,and they are the best!!!
Tnriverluver
Late 1990's on up Stratos boats are all composite and they are fast with an exceptionally good ride.
Philster
I hesitate to pat bass boat builders on the back. Not exactly "taking it to the seas" given their typical use.
haulnazz15
Agreed, Philster. Most of the bass boats I see never venture into more than 1-2' chop at the most, and it usually just above planing speed, lol. Our bass boat will knock your fillings out in light chop at full throttle (only 40-45mph). They weigh nothing and have almost no deadrise. It's really a slap in the face to Allison for you to say they have low hull integrity when compared to a class of boats that don't really have much they typically withstand, lol.
Slip Away
Finn-Craft boats are made in Minnesota plant that Larson is made. VEC construction, no wood. Fishy boats are all they make.
well there some intresting infomation here. i looked at a ranger 391v that was going cheap but the stress crack on the left side top of the transom didnt give me a warm and fuzzy felling also the stress cracks on the internal wall between the battery storage and the other storage lockers looked real bad like the boat side had tryed to fold in . i like the Stratos and now i know that a post 1990 is a good place to start. what i look for in a boat is a side by side with raised fishing platforms and a troll motor. the other thing i need is a boat that can sit on a trailer in florida with out me wondering if its slowly rotting away from the inside.
Philster
If you're operating from a premise that no wood always = good, you might want to consider the possibility that you are working from a flawed premise.
Theorem: Properly encapsulated and cared for, many quality builders have yet to see any other core material rival wood for strength, durability and workability.
Some big center console builders are challenging that opinion by going 100% wood-free construction and really spending a ton on the newest non-wood composites (remember, the #1 composite is still balsa wood core). They seem to have it down, because their hulls are heading out to the canyons and beyond and coming back strong.
The problem here is that all this is the sum of the latest, most expensive and most labor-intensive construction methods going on. These are expensive boats and there are lots of hands going into making what amounts to custom offshore boats.
For most assembly-line builders, who don't have the luxury of experimenting with incredibly expensive boats and doing custom, labor-intensive processes to deal with non-wood construction, there remains a number of questions:
Ok, there is no wood to rot, but what happens when your core material gets wet? Possible answer: "Our core material, borrowed from aerospace technology, can actually hold twice as much water as wood". Consumer ponders: That can't be good.
There is no wood to rot, but when your core gets wet, does delamination occur: "Well, of course, and you can't repair it as easily, because it's proprietary construction and proprietary adhesive technology."
How strong are the overall hull and deck? "It's almost as strong as wood".
So, what do you do about that shortcoming? "We squeeze foam into every goddang inch that we can".
etc...
diehardmason
I have a '96 Ranger R70 and am quite proud of my boat. I am fairly new to boating,, but, have been enjoying the life of a boat owner up to this point. I don't think it is proper to criticize bass boat makers because they don't hit the "high seas." The boats are fit for their purpose. They bring you to a spot to fish quickly, in a very light chop and are extremely comfortable to fish. So to compare them to the larger boats, in my opinion, is truly irrelevant. The OP asked a simple question about boat materials.
Ranger, Triton, Nitro, Skeeter to name a few all fiberglass bass boats. We fish small lakes here b/c big water is hours away from us here in South Louisiana. So most people own bass boats or tinnies. Some have bay boats and larger, but, those guys live on the Gulf or have quite a run to the Gulf. Just b/c the boat you have looked @ has stress cracks doesn't mean all boats have them. Take your time and don't be rushed to purchase. I looked around for two years before I found one that I felt was reasonable and in decent enough shape for me and my level of skill. I am sure you have boaters that can advise you in some way. I went to new dealers and asked questions about boats and found the things that interested me in the boat I was looking for. There are plenty of options. Just take your time and make an informed decision. Some of the posters will actually answer your questions and truly be helpful. Don't mind the others.
Philster
Yes, don't mind me; I am always fighting ignorance.
diehardmason, don't take the issue personally, please. Whether one is sourcing a bass boat or offshore pounder, one should be informed. Would be a shame to miss a great deal on a boat that contains some wood and would provide lifetime of happy service if cared for just because one has discounted wood without sufficient information.
Peace.
with your help and alot of reading i bought a 91 stratos 16.2 with a 140hp evinrude strapped to the back of it. i liked the price, my truck could tow it and the seller insisted that we drop it in the lake and take it for a spin as even a poor engine can run on ears. after speaking to the seller for a while and reading the posts from other boat owners and people who fish in this area im realising that the boats construction isnt the problem the past owners have way more to do with it. the boat i bought isnt a trailer queen but its solid and it hasnt been smashed around in the lake. with a few hours work i can fix the minor gremlins and im going to look at other posts in the forum to make her pritty again. it was nice to see the boat backing off the trailer under engine power and nothing flexed or juddered. i guess the old school verses new school construction will keep every one busy in the forums the same way premix oil did and proberly still does.
just had to add .....philster that quote "We squeeze foam into every goddang inch that we can" made me laugh (im just glad that they do as i dont alway remember the plug until i see the biege pump running) and diehard as 50% of the boats here are bassboats and the one everyone wants is a ranger dont fell im insulting the boats because ive seen a bad one i was just more shocked that you could break a ranger as there meant to be the best of the best. the last owner proberly has a story that goes with breaking the transom.
phil does raise a good point about how would you repair it say you ran into a tree stump or something (happens alot at lake okeechobee as the water level changes during the year) well going fishing tommorrow in the stratos be it wood, composite or a block of foam i still bet i dont catch anything but im going to be smiling
