Which Bravo & where do i connect muffs?
Bt Doctur
Re: Which Bravo & where do i connect muffs?
check for a thru-hull fitting going to the raw water pump.
ormjgrouch
Checked for thru hill fitting nothing. Any ideas?
Bt Doctur
tell us where the hose from the raw water pump connects to.
ormjgrouch
I will look tomorrow, thanks for your response bt! Have any idea what bravo it is 1 or 2, I think it's a 1. Thank you
Ayuh,.... It's a B-1, 'n if ya follow the hose from the impeller pump, it'll lead ya to a thru-hull water pickup,...
ormjgrouch
Bondo thanks for the response. Time for me to get a manual on bravo 1s
Ayuh,... Up in the Adults Only section, follow the links in the Mercruiser Info thread,....
ormjgrouch
Bondo your the best....
muc
"Retired" Association of Marine Technicians...
This is called a low water pickup.
In front of the prop at the bottom of the leading edge of the lower unit will be about 5 holes.
You need a special flusher from MerCruiser.
ormjgrouch
Thanks muc, I don't recall seeing but will check again tonight.
ormjgrouch
Finally, found it, duh.. Ordering my muffs now.
MarkSee
Do a search on "Bravo 1 low water pickup" as you need to be a little more cautious with this type as it is more prone to getting plugged up with sand and mud.
Mark
