rickdb1boat
- Joined
- Jan 23, 2002
- 11,195
I have 2 batteries on my pontoon boat that I would like to be able to charge without the hassle of removing them. They are stored in a compartment that is partially open but a real bear to get to when I need to hook up a charger. One is a deep cycle for the troller and the other is my starting battery. The only thing I run with the deep cycle is the troller. Everything else is hooked to the starting battery which, of course, is charged by the motor. I want something that will let me charge quickly or just trickle charge during layup. Anyway, something I could mount inside the compartment that hooks to the batteries for charging and yet have access on the outside to plug it up for charging easily. Here's a pic from the back of the boat showing where the batteries are located. There is a shelf located inside that area that is about even with the bottom of that white side panel(Next to the text) that is a pain to pull out to get to the batteries. Any ideas of a simple set-up? Thanks,
