Which coil to use?
tank1949
My coil may have gone BAD. It says "Mercruiser" on the coil's body, but faintly. No other writing is available. It is installed on a an older 350/stroker carbureted motor using a MC TB5 ignition system. I believe a Chevy automotive internal resistor coil could work on the TB 5 but I am not 100% sure. Manual is not clear on coil required to be internal or external resistor type. In addition, should coil be HEI? Or are they all HEI?
dave8311
Coils very rarely go bad. I would troubleshoot more before throwing parts at it.
Bt Doctur
but if it did go bad, any gm coil for electronic ign will work. They have internal resisters
tank1949
We are. We cannot get fire out of main coil wire with helm switch on. 12 volts is coming to + side of coil. Main lead should arc between spark plug contacts but no arc. We will rotate with our stb motor's working coil to further rule out coil. Motor has set for 4 years due to my health issues. Moisture may have gotten inside.
Scott06
Thanks. I have tested about 1/3 way. Is there a difference between HEI and regular coils?
Electronic ignition coils like used on HEI have an internal resistor, points type coils use an external resistor. Will have a resistance wire in Barnes or ballast resistor to lower voltage to not burn up
Points
tank1949
Points
I had forgotten that. I had a senior moment! THX
