OK in a previous post I talked about a coil overheating problem and need to replace the coil but want to be sure I get the correct one. My 1983 3.0 Mercruiser was converted to electronic ignition (no points) by the previous owner so I have no instructions. I do know that it uses a 12v without a resistor wire. I believe the unit is a pertronics unit from the markings but cannot be positive. I replaced the coil a little more than a year ago and it is bad once again so perhaps I did not have the correct one. I would like to ask the good folks on here what would be the recommended or the proper coil for this engine. I looked up coils but am a bit confused over the different specs on these coils as I am no electronics whiz. Thanks in advance for your most welcome input.
