Done all of that. Everything checks out. I’ve been fighting it for 2 summersDon't know if the ECM is your issue but need to start by measuring fuel pressure. If it's within spec then need a scanner to check for codes
https://www.rinda.com/marine/marinemenu.htm
Does it stay there when running/cruising?Yes, that’s the range of the fuel pressure when we check
Both have been replaced. Vst… not trying to sound dumb… is that a small tank?Are you replacing the high or low pressure pump?
There may be a vst for the high pressure pump. I've seen those get blocked up with debris more than once
