Re: Which electric fuel pump to use for priming my 98 200 HP carbed Mercury outboard
There are a couple of ways to use an electric fuel pump. If your just trying to get rid of the squeeze bulb, Merc recommends using a 2lb electric fuel pump and retaining the pulse pump. This method works well and you can retain your oil injection system.
For those of us that have removed our oilers and run pre-mix, Holley makes a marine grade USCG approved fuel pump in either the Red or Black version. I run the Red and pump 4-5 lbs at the engine after the lift up from the fuel/water separater. I then remove my pulse fuel pump and use a block off plate to cover the pump vent and remove and plug the pulse fitting.
Here's what mine looks like:
If you're scared about what Silvertip say's, his concerns seem valid but apparently Merc and Evinrude don't think so because most of them run electric fuel pumps now.
I suppose if you are really paranoid you could set up a circuit that got a reference signal from the rotational sensor next to your oil pump.
Personally, if I smell smoke or see fire in my engine, I'm turning it off at the keyswitch and that will instantly kill the fuel pump. It's not the raw fuel that's going to go ka boom, it's the fumes. A small leak under the cowl is far more dangerous that a big one.
