Which engine will an Alpha One outdrive fit?
whodunnit
I read about different model years and descriptions/sizes of mercruiser engines, 4.3, 260, 3.0, 350 magnum, etc.
A lot say "With an Alpha One outdrive" Does the same outdrive fit all engines? If not, where would one look
to find the correct match up?
Bt Doctur
Re: Which engine will an Alpha One outdrive fit?
any engine up to 300 HP will fit the Alpha. It`s the gear ratio that really matters
Ayuh,... The Alpha 1 drive is an Alpha 1 drive,...
The gear ratios change to match whichever motor's turnin' it,...
whodunnit
So it does matter, and it appears the gear ratio is the difference. So, again, I humbly ask where/how would one
find the information as to which gear ratio is compatiable to each engine?
Thanks in advance.
Thanks in advance.
Ayuh,... Up in the Adults Only section, at the top of this forum,...
whodunnit
WTF? Is this your way of telling me how to ask a question by the rules? Knock off the condescending BS.
I am not working on one specific engine or outdrive. I merely wanted reference info. I doubt you have them all memorized.
If you do, prove me wrong and list them all.
IGeeky1
chill, look first then when you find the info he tried to connect you to and you don't like it, come back and dress him down then.
...or apologize.
whodunnit
IGeeky1: It's nice to see someone attempting to keep the peace, I'll apologize.
Bond-o: I've read way too many of your posts. You demand quite a presence. I'm sorry you're condescending.
Ayuh,... I said Nothing of the postin' Rules,...
there's Tons of Information in the Adults Only section on Mercruisers,...
If you can't Read it for yerself,....
Why should I type out all the info,..??.. Again,..??...
I'm a single digit typist,... I ain't wastin' My time retypin' info that's Already posted,...
There are 5 different ratios that cover the motors available,....
Yes, I know 'em,...
I'm sorry you consider gettin' the answer to yer question, condescending.
81 Checkmate
Best Answer: Condescending means snobby, behaving toward other people in a way that shows you consider yourself socially or intellectually superior to them ...
If it wasn’t for Bondo’s knowledge……..We/I.. (A lot) of us would still be sitting in our boats staring at our engines wondering what to do next!
So im glad he is intellectually superior than i am about boats............ He could very well spend his time doing other things than helping us.
I take it you’ve never been in the North….That’s the way northerners are…. Straight to the point
Google has many powers…….No need to have someone type out the answer for you.
I sometimes post part number questions…In fact just the other day…..But after I hit the send post button…I thought, cant have them do my research for me.
So I did and found the info I needed.
Ok so I vented……..Have a good Day!
