Re: Which epoxy do you use?
Sure, West Systems is just about everyone's fallback position if for some reason they need some epoxy real quick and can't wait to order some. You can get the West Systems stuff anywhere. Its a very good product, its just expensive. With any of the epoxys consider it a system one resin and the same company's hardners, if you change resin then change to the same systems hardners. Don't mix them up. For one thing the ratios may be different as well and that is something you have to get right with Epoxy. Never guess on ratios, use graduated cups to mix in.
