Fiber guys
Which is stronger, the fiberglass mat or woven? I will be using epoxy and the stronger fiberglass to rebuild my deck lids. All of them are cracked on the hinge side. Opinions and adviced needed.
strength comes from as much cloth and as little epoxy as necessary (ask any surfboard builder). You might also consider using a kevlar, feldspar epoxy paste for max strength - like wet dry 700 (tm) - it is thick but it will wet out the fiberglass cloth (often used with fiberglass cloth for pipe wraps at chemical plants etc. )
