I had decided to buy the Eagle 480df because it had a dual range transducer, temp and speed plus 480x480 resoulution. Then I saw this...."If you need a deep water finder this is the right one, however, if you are fishing inland waters a dual frequency unit is the wrong choice, you should select a single frequency unit because on high sensitivity it has a 60 degree 200 Khz cone verses the dual frequency that only has an 8 degree 200khz cone. The 200khz is the only frequency that sees fish.<br /><br />The Dual Frequency is great in deep water and very poor in shallow because the 50khz in the dual frequency shows deep bottom structure but not fish." <br /> Is this true do I need to get a 200khz transducer to see fish?
