Which gasket??Can anyone Tell me what part I need to replace from this video
The lawn ranger
87 mercury 150 xr2 ser 0B199676 and thank you, I really appreciate it this site has helped me a lot on this motor
  • 20230908_141350.mp4
The lawn ranger
And i suspect i may have Some blockage around the exhaust plate i, faster you go the hotter it gets
flyingscott
looks like a bad gasket or an overheat warped the plate. will need to remove to find out.
Dukedog
don't forget #3 (tubing, seal).... also check both pieces for any cracks while ya have 'em off...............
also if any of tha exhaust ports are really clean ya may need ta take a closer looks at tha pistons and cylinders.........
The lawn ranger
Are you talking about the gasket at the exhaust plate or the gasket divider plate under the exhaust manifold? And would this cause an higher rpm overheat? And thank you for all yall s help.
Dukedog
looks like more "divider" than power head ta me.. could be power head maybe?..to much water..
The lawn ranger
Thank you.. would that make more sense why it overheats at higher rpm,? Maybe a blockage at the exhaust divider plate ? Dont know just asking trying to make sense of it all, its getting more and more frustrating. Thank you for responding, thought about looking for a mechanic but might be cheaper to look for a psychiatrist
Chris1956
Overheat at high RPM can be caused by compression leaking into water jacket, poppit valve malfunction, bad thermostats, clogged main jets, etc. Not sure if leaking gaskets cause overheat.
In your case, you might take a compression test.
Chris1956
You also might check poppit to make sure it opens at about 2000RPM. Otherwise, water pressure can get high.
The lawn ranger
Yeah I'm going to double check the poppit tonight, I hope that's what it is thank you for your response
