Which gearcase lube for 1960 Lighttwin?
huntandhook
Hello,
I was wondering what type of oil I should use in the gearcase of my 1960 Evinrude Lighttwin 3 HP? It is the no shift model with the weedless drive. Above the drain fill plug is says "fill with hypoid oil", but it doesn't state the viscosity. I have a bottle of OMC hi-vis gearcase lube that I was going to use, but I want to make sure it is the right stuff before I fill the gearcase. I looked in a crappy repair manual and it says to use OMC Type "A" lubricant. Can I substitute the Hi-vis for the Type "A"?
Any advice would be graetly appreciated.
Thanks,
H&H
tashasdaddy
Re: Which gearcase lube for 1960 Lighttwin?
that's replaced the type A. you fill from the bottom and let air escape the top. that way you know it's full. they now make a $10 pump to make it easier.
samo_ott
The $10 pump is worth it's weight gold if you do it more than once a year... It saves a big mess.
F_R
Hypoid" oil is 90 weight. Hi=Vis is an excellent more up-to-date oil. Actually, that motor is not fussy. Plain ol' 80-90 outboard gear oil from Wal-Mart is just fine.
